can you remove the starter clutch as an assembly ie remove locknut and pull it all of together, or does it come of piece by piece,
the lock nut is off but i cant see whats next.
cheers guys.
mark.
how 2 remove the starter clutch
- Novice racer
- Suzuki 2-Strokes: gt750
1973 SUZUKI GT750K.=SOLD
1982 HONDA CB900F =SOLD
1982 YAMAHA RD350LC.
1985 RZ350N
1985 RZ350N
I use a steering wheel puller that has the correct spacing - you need something with bolts that you can thread into the face of the starter clutch assembly, and then allow you to pull straight off. Don't try to use a gear puller (with hooks) as that will risk ruining the starter clutch assembly.
- GT500Andy
- Country: Netherlands
- Suzuki 2-Strokes: T500R, GT500A, TS400, V strom black rhino
- GT500Andy
- Novice racer
many thanks
many thanks,
mark
mark
1985 RZ350N
1985 RZ350N
