I've got the wiring harness back on my 1975 GT 250, but am not really sure where the rectifier and flasher relay goes. Can anyone provide me pictures of both sides with the covers off? thanks in advance!
Patrick
Can anyone provide some GT 250 pictures
- Suzuki 2-Strokes: GT 250
- Country: england
Re: Can anyone provide some GT 250 pictures
look on the left side and there's a little 'D' shaped hole in a frame bracket behind the sidepanel. the rectifier goes in there. flasher relay goes to the left of it. but further in
Thanks @dollydog
I was assuming the rectifier mounts on the outside of the frame tab, but the wires don't look routed right, not sure if it can rotate on the mount stud, but that could be it. Does the flasher connect on the inside part of the tab or another bolt?
Patrick
Patrick
This pic I found online looks pretty close to stock.
This bike has a voltage regulator attached to the top of the battery box — your bike likely doesn’t have one.
The pic is from here:
http://www.motowasabi.com/archives/cat_suzukit250.html
- Country: england
the rectifier definitely goes on the inside of the frame. looking at the above photo i'd say the flasher unit attaches to the rectifier bolt. i always put my flasher units further in, but there again i use led flasher units
Thanks all. Let's see if I can get this thing wired and ready to run this weekend!
