Repo Turn signals
Re: Repo Turn signals
Scorch wrote:Uh, what's the difference? :lol: Where is the flasher?? The thing I asked about?
On that model, don't you just flick the switch on and off on the handle bar as required ? :D
Seriously - it's the round can you showed in the photo you posted and should be mounted on the electrical terminations plate under the left side cover in the area of (likely above) the rectifier. Is yours missing completely ? 8)
gt-keith
Suzuki 2-Strokes: GT380 & GSF650 Bandit
Post by gt-keith »
Hi Scorch,
The turn signal flasher you asked about, is mounted on the front lower left hand edge of the battery box. If you remove the left hand side panel you should be able to see it, bit fiddily to fit.
My 380 had an aftermarket flasher fitted when I bought it and the signals used to slow down and eventually stop, got a NOS relay which works perfectly.
gt-keith.
Scorch
Born to ride
Suzuki 2-Strokes: 1975 GT380
Post by Scorch »
Ok, thanks guys. Terry's comment about "flasher relay" threw me for a loop. :lol: I will have a look for it tomorrow, thanks, and see about replacing it with something basic from Autozone.
KraigG
Post by KraigG »
I ordered a front and rear set for my GT750L from this vendor. Quality looks to be good, and though I asked for red lenses for the rear, he misunderstood me, and sent red reflectors by separate mail. Turns out that he doesn't carry the red lenses.
1974 GT750
1972 CB750
Scorch
Born to ride
Post by Scorch »
Ok, removed the left side cover, the flasher is between the battery box and the air filter, and right behind the frame member. Looks like the battery box has to come out to get to it.
Scorch
Born to ride
Post by Scorch »
Update, was able to get the old one out easily by removing the tool bag holder, one bolt. Spliced in a $5 550 series flasher and it works perfectly!
TLRam1
Post by TLRam1 »
Do you still have the old one?
Terry
Scorch
Born to ride
Post by Scorch »
The old signal flasher? yes.
TLRam1
Post by TLRam1 »
If you don't want it I will take it.
Terry
Scorch
Born to ride
Post by Scorch »
No problem, PM me your mailing addy.
TLRam1
Post by TLRam1 »
PM Sent.
Thanks.
Terry
Scorch
Born to ride
Post by Scorch »
...and flasher sent (hate to leave a topic hanging).
