Do the GT380 and GT550 and the GT750 use same points?
bobotech
Post by bobotech »
I have a 75 GT550 (nippondenso) and wonder if the nippondenso points from the GT380 or GT750 would work on my bike?
My shop has some NOS Nippondenso points tuneup kits that must be from the late '70s/'80s and I just want to get the points from them for my bike. I am trying to cross reference the points at this point.
TLRam1
Re: Do the GT380 and GT550 and the GT750 use same points?
Post by TLRam1 »
I have different kits for my 380 and ones for the 750, whether you can retro fit, I don't know but my kits are bike specific.
Terry
According to the Zedder cross reference, the points sets are common between the GT550 and GT750. 8)
bobotech
Post by bobotech »
Hmm.
What about the GT380 and GT550?
Nope.
I see two types of points listed - Denso - which is evidently unique to just the GT380. And Kokusan which are common across GT250, GT380, TC305, T125, T250, T305 and T500 models depending on year, but broadly speaking between 1967 and 1977.
Not GT550 though. 8)
What makes it tricky is Suzuki used two different ignition systems in the GT550 production. My 75 is Kokusan, but the next guys might be Nippon Denso. The points do not interchange between the 2 systems. The points cam is also different, meaning you can't use a Denso cam on a Kokusan points plate and vice versa.
H2RICK
Country: CANADA
Post by H2RICK »
Absolutely !!! 750 and 550 all same same.....IF they're Nippon Denso.
I inherited a nice new set of genuine Suzi ND points and condensers with the '77 Buffalo I picked up a number of years ago. I checked them against my 550 and they're a perfect match. So, if my 550 points EVER wear out, I'm ready to install a fresh set. :up:
GT550A Mint & Original
MBD Sufferer
jeff g
Suzuki 2-Strokes: GT550 -- 1 running, 4 not, '80 TS185
Post by jeff g »
The nice thing is that the Kokusan and Denso ignition systems are completely interchangable...you just have to change all the parts as an assembly. Denso points are more readily available than Kokusan.
