Tall gt750
- fregado
Tall gt750
Is there a gracefull way to lower the back end or seat on a 74 750? My butt isn't that far off the ground and a couple of inches would be a huge help but i'm not seeing a viable way to get it.
Life is short, have fun doing it.
- Suzuki 2-Strokes: GT750
Re: Tall gt750
Man you're not kidding! I think that's a big part of why they call it a water BUFFALO. I know Johnny (bighole) is running a smaller 16"? rear wheel on his '73 which lowers the rear end just enough to make the height reasonable, although the pipes will drag a bit easier on turns. You could PM him to see if he knows what it came off of.
1974 Suzuki Nomad 340
Re: Tall gt750
I have the same problem. I had an upholstery shop cut down a recover a stock seat. Cost around $100 but was well worth it!
- johnakay
- I likes them jubblies
- Suzuki 2-Strokes: bike
Re: Tall gt750
get a pair of these much cheaper and problem solve one one swipe. trust ya uncle John I'll keep ya right and save ya money to
- Novice racer
- Suzuki 2-Strokes: gt750
Re: Tall gt750
love it john,
1973 SUZUKI GT750K.=SOLD
1982 HONDA CB900F =SOLD
1982 YAMAHA RD350LC.
1985 RZ350N
1985 RZ350N
- fregado
- H2RICK
- Country: CANADA
Re: Tall gt750
John, have you got those with some glitter dust on 'em....and maybe something in a little wilder colours ???
GT550A Mint & Original
MBD Sufferer
MBD Sufferer
- johnakay
Re: Tall gt750
H2RICK wrote:John, have you got those with some glitter dust on 'em....and maybe something in a little wilder colours ???![]()
not now
Re: Tall gt750
Fregado,
Heres my 73 with a 16" wheel. Not sure the origin of the wheel as it was on the bike when I found it. Some said once it might be a Harley wheel...
Not much height difference as smaller rim meant taller tire(and wider too)!
-John
-John
My bike is a "bighole" I keep throwing money into, so I had to get another!
09 Aprilia RSV1000
73 gt750
77 gt750 cafe
73 gt550
74 RE5
09 Aprilia RSV1000
73 gt750
77 gt750 cafe
73 gt550
74 RE5
Re: Tall gt750
From the rear...
09 Aprilia RSV1000
73 gt750
77 gt750 cafe
73 gt550
74 RE5
09 Aprilia RSV1000
73 gt750
77 gt750 cafe
73 gt550
74 RE5
Re: Tall gt750
I had forgotten about the larger tire which is probably the reason nobody notices its on a 16" rim. I imagine fregado could fit a smaller tire to lower the bike but it probably wouldn't look as gracefull as yours does. Let's not forget you found the bike half buried in the mud behind a barn! The best option seems to be modifying the seat. For about $100 it seems to be a more cost effective solution too.bighole wrote: Not much height difference as smaller rim meant taller tire(and wider too)!-John
Re: Tall gt750
Just a bit curious about your 16" rear wheel.
What's the rim width & tire size?
Re: Tall gt750
Common enough "upgrade" in the day. 16" Dunlop rim, laced to a stock hub. I've got one, seen two others, and now 3 with yours, John. Tire choices are the limiting factor, all seem to be cruiser related, and quite high sidewall. Little difference in overall height. I have a brand new, unmounted 16" rim if you want, but without a low profile tire to go with, it wouldn't solve your problem. Coyote has the only logical solution, with seat mods. Or John's boots, of course. Any other changes would compromise the already shallow lean angles allowed by the stock set-up. Eat your Wheaties, and grow a couple inches. That should do it. Cheers.
Fred
Fred
Suzuki GT 750s
Ducati 750 GTs
2007 Duc 1000 GT (the clone)
Suzuki RE5s
Ducati 750 GTs
Suzuki RE5s
- fregado
Re: Tall gt750
I had to reupolster the seat anyway (duct tape is functional but butt ugly) so i took a couple inches off of it in the process, made alot of difference, also the flatter seat makes a more comfortable ride. Thanks for the input everybody.
