GT250/H1 Squish band heads
A place to list e-bay items you think others would like to know about.
Eric P
Suzuki 2-Strokes: FA50, T250R, T350R, GT380J, T500R
Post by Eric P »
Maybe someone on here might be interested in these:
http://www.ebay.com/itm/Suzuki-GT-250-G ... Vr&vxp=mtr
Re: GT250/H1 Squish band heads
We are working on a 73 GT250 cafe project. Motor will be stock except for K&N pod filters + Higgspeed exhaust.
Any insight on what these heads do to performance?
Eric P
Post by Eric P »
These heads give you a higher compression ratio and will give you a bit more low end. They reduce the head volume from 14.0 cc to 11.5 cc. The squish band will give you an increase in combustion efficiency and a decrease in detonation.
Eric P
Post by Eric P »
A side note: you would definitely need to check your squish clearance before running these as there are minor variations in cylinders and engine cases as well as various gasket thicknesses. You probably want your squish band at around 0.6mm
