does any one know if the handle bar's are made of?
yes I know steel tubing but what grade??
I have some guys at the show asking if I'll make some.
but the materials that I used is only mild still and I dont think it will be strong enough even if its 2mm wall thick and while we're at it what size is the RE5 handle.tubing that I have is 19.5mm(3/4")
handle bar's???
- johnakay
- I likes them jubblies
- Suzuki 2-Strokes: bike
handle bar's???
Re: handle bar's???
John, I know bugger-all about metallurgy but I would have thought the grade you use for your racks and grab rails would be ideal, certainly the grab rail would have to cope with the same sorts of loading and stresses as the handlebars.
- johnakay
Re: handle bar's???
my current stock would be to thin for this.
it would need to be at least 2mm thick.
I'm surprise you've not chip in Allan seeing that you have an RE5!
come on what size is the bugger!
Re: handle bar's???
Aren't almost all bars a standard 7/8" and simple steel tube? They aren't seamless and they are not very thick.
Someone should have a bar they can measure to confirm the gauge of tube used.
- Suzuki 2-Strokes: 74 GT550
Re: handle bar's???
The original bars from my 74 gt550 are 2mm thick. I have 2 other aftemarket bars. 1 is 2mm, the other is 2.4mm
1974 Suzuki GT550
1983 Honda XL250
2002 Yamaha Bear Tracker
1959 Lone Star Malibu
1983 Honda XL250
