Stripped fork studs
- Bmurphybcr
- Country: United States
- Suzuki 2-Strokes: 1973 GT250k
Stripped fork studs
So I just got new tires mounted and balanced, and after I got the axle in place I torqued down the nuts. The manual said to torque them between 26 to 37 ft lbs so I went for the middle and torqued them to 32. The left side went fine, but when I torqued down the right side I stripped the threads on the stud. I was able to get the nuts off by using a wedge to push the nut down while I loosened them. What are my options now? Should I use a die to cut new, smaller threads on the stud or can the studs be removed and replaced?
Re: Stripped fork studs
Replace them. Recutting smaller can compromise strength. You don't want the wheel to come loose.
- Bmurphybcr
Any idea where I can find replacements? I can't seem to locate any. Even the parts diagram of the fork doesn't show it as a separate piece. It's for a 1973 Suzuki GT250.
Remove the old one(s) and measure the length. They are 8mm thread. Any local bolt or fixing supplier will have something similar or even a bolt. Use new washers too.
Suzuki parts diagrams list those studs for some of the other models.
GT250K: https://www.partzilla.com/catalog/suzuk ... ork-gt250k
GS550: https://www.partzilla.com/catalog/suzuk ... front-fork
Those GT250 studs were used on lots of other models. With a bit of sleuthing you should be able to get a useable net set from Suzuki.
Looking at the GT380 shop manual: https://www.oldjapanesebikes.com/mraxl_ ... /index.php
The front axle nut spec is 26 — 38 ft-lb. That is the big nut on the axle.
The front axle stopper nut is 9.5 — 17 lb. Those are the axle holder nuts that you torqued up to 32 ft-lb.
Would be a good to replace all four of those studs & use new washers + nuts.
- Bmurphybcr
Thanks for the advice. Replacing it was cheaper and easier than cutting new threads.
