What crazy things have you seen done with your model Suzuki?
dollydog
Country: england
Re: What crazy things have you seen done with your model Suz
Post by dollydog »
hi jab, thanks for the input. the 2 ideas i had were: make a 10mm spacer between the sidestand bracket and the frame bracket and bolt the sidestand on, just to see where it sits. if it's too low i'll bomb that idea. :D
or, i've got a spare frame bracket off a hacked up old frame, and i thought of welding it on much further towards the front - on the same frame rail. i've already got another crossmember to go under the engine, so it could butt up against that and weld there, as well as being welded to the bottom [main] frame rail. so it would definitely be strong enough :D
yet again, unfortunately i can't try that until i strip the bike down again, ready for powdercoating. i'll measure how much the spanny sits below the main frame rail and see if it will tuck in nicely or stick out - then back to square one :D i suppose i could always alter the sidestand bracket, so the sidestand opens the opposite way and weld the frame bracket on the right side of the bike. so, it would have a right hand sidestand, but where's it say you can't? decisions, decisions :D
My strategy was to get the side stand pad & tab to be behind where the exhaust starts to kick up.
I tried a 73 GT250 side stand bracket & its bolts up to the GT380.
So you can use a T500 bracket & do something similar with your GT250 frame.
dollydog
Country: england
Post by dollydog »
tbh jab, i think it would be easy enough to make one. it's only about 5mm plate with an extra bit welded in the middle for the bolts. i suppose what i could do is take the exhaust off, fit the sidestand and see if i can get the exhaust back on. hmm, sounds a bit irish to me :D i've got a t500 frame on the yard, so i'll have a look at the bracket tomorrow morning when it's light. 9 o'clock at night here and pitch black :D . i'll get back when i've sorted something.
dollydog
Country: england
Post by dollydog »
right, after wandering round with my torch and looking at the t500 bracket, it's exactly the same as the 250. so, i think the easiest option will be to weld my spare bracket on further up the bottom frame rail. it should fit in nice and snug, but the arm on the sidestand itself will need lengthening. easy job. harder job is making a new gearchange lever to fit over and round the spanny. gonna start that in the morning :D unfortunately with clip-ons fitted, when my feet are on the footrests they point downwards, so need to sort that first :D
sportston
Country: England, UK
Post by sportston »
DD, can you shorten your feet? Try smaller shoes so they don't scrape the ground?
:wink: :wink:
dollydog
Country: england
Post by dollydog »
i've done this:
dollydog
Country: england
Post by dollydog »
quick change to this. just the first fit, not a rat bike :up:
sportston
Post by sportston »
Cool. Well done
sportston
Post by sportston »
That will be a pretty cool Kwakazuki. Are you going to go with the ramair motor or the normal style one?
dollydog
Country: england
Post by dollydog »
the frame, just back from the powdercoaters :D looks better in the flesh though :)
dollydog
Country: england
Post by dollydog »
i've started, so i'll inish :D
sportston
Post by sportston »
Looking smart so far. Charming mug you have there. I wonder if I could fit that slogan on the bottom of my number-plate. :D
dollydog
Country: england
Post by dollydog »
thanks :) regards my shed mug, it's a proper shed mug, bought for me some years ago by my local landlord, who thought it would appeal to my weird sense of humour and outlook on life :)
here it is in all it's unwashed glory. don't look if easily offended :lol:
http://2strokeforum.com/thread/17782/in ... llydog-mug" onclick="window.open(this.href);return false;
No pic showing for me Ade, but the bike is coming on well, bud.
Zunspec4
Post by Zunspec4 »
A very nice build, dd :up: Looking forward to future instalments.
Cheers Geoff
