Help, need an electrical wiz
- Country: United States
- Suzuki 2-Strokes: 1975 GT550
I'm trying to wire a gauge cluster from a 98 GSXR 750 to work on my 75 GT550. Is this possible?
Re: Help, need an electrical wiz
Everything is possible.
Do you have a wiring diagram for a gxsr750 so we can compare?
Bearing in mind the GT550 is analogue and 2 stroke and the GSX isnt, the rev counter & speedo probably won't work. Use a different dash like the Vapor which I had on mine like this - viewtopic.php?f=2&t=11247&hilit=Earwig&start=30 way down the page......
No I dont have a wiring diagram. Are there other dashes than the Vapor?
Lots on ebay.
This is my T500 cafe build with an Acewell speedo/tach + bracket + speedo cable.
cafe-T500-2096 by jabcb, on Flickr
Mechanical gauges are cheaper & easier to install. Uses stock Suzuki drive cables. You just need to wire up the lights.
Mechanical gauges on my GT550 cafe build.
cafe-GT550-0827 by jabcb, on Flickr
Thank you for the reply's
