howdy all,
i am most of the way done fixing up a 1973 GT250 for my girlfriend, i've got the motor torn down and cleaned up, fresh top end ready to go...
i'm having zero luck finding a seal kit for the bottom end of this motor, i was able to find crank seals from crusin image, but not pushrod/starter/etc...
they list a complete seal kit for a GT550, but i have no clue if that includes the same seals that will work for a 250 bottom end and have had no luck getting them to reply to any of my emails...
does anyone here know a source for these seals, or know if that kit they sell has what i need?
many thanks
GT250 seal kit
- Country: United States
- Suzuki 2-Strokes: 1973 suzuki gt250
- Country: United Kingdom
- Suzuki 2-Strokes: 1966 T20
Re: GT250 seal kit
Just measure (if the dimensions are not on the seal) and and bearing factors (eg Simply Bearings) should be able to supply you. They should all be pretty much standard seals. Slight differences in thickness are not usually a problem.
Keith
Keith
1927 Scott 3 Speed Super Squirrel
1948 Scott Flying Squirrel
1951 Cyclemaster
1966 Suzuki T20
1981 Montesa 349
1985 Suzuki RG500
1999 Honda CRM250AR
Definately NO 4 strokes
1951 Cyclemaster
1966 Suzuki T20
1981 Montesa 349
1985 Suzuki RG500
1999 Honda CRM250AR
Re: GT250 seal kit
Welcome to the forum.
Get a criuzin image gasket set via eBay or directly from them.
https://www.cruzinimage.net/?s=suzuki+gt+gasket
Most of the oil seals are still available from Suzuki. Order online or via your local dealer.
https://www.partzilla.com/catalog/suzuk ... ansmission
The oil seals that are no longer available are typically on eBay — search for the part number (i.e. suzuki #####-#####).
The oil line washers that Suzuki now sells are awful. Get Stat-O-Seal washers for McMaster-Carr or somebody else.
A forum member sells a seal kit for the oil pump on eBay. Be careful — the pump bleed screw has left hand threads.
DO NOT USE COMPRESSED AIR TO FLUSH THE OIL LINES!!! That will ruin the one-way valves. Lots of forum post explain how to deal with the oil lines.
