Another broken fastener removal method.
Arne
Post by Arne »
Well, I broke a cam retention collar off flush down in a little hole and the normal stuff (pliers, vice grip, file, chisel, left hand drill bit, impact screwdriver, easy out, grabber easy out, etc.) wouldn't work.
So I took it in to get a helicoil put in and the mechanic 'wouldn't touch it'. Of course that made me want to get it out by myself, and I did in about 5 minutes.
I stuck a hollow retention dowel down in the hole, welded the end of the stud to the retention dowel, and then just turned the dowel out.
I think I might have a new use for that box of roll pins I have laying around!
1981 Honda CB750-1000 driver
1982 Honda GL500 easy project
markj
Post by markj »
Hmmm. That's clever and it worked! There's nothing worse than extracting flush broken studs.
Cool! :D :D :D :D
kmil
Suzuki 2-Strokes: T350
Post by kmil »
I'll put that one in my memory bank. Thanks.
kmil
