Oil leaky
TC
Oil leaky
Post by TC »
Oil leaking somewhere in the front of the engine, below the exhaust ports. Does not seem to be goo and dribble from the exhaust, but seems to be injection oil consistentcy. Could this be something to do with the sris system? Is it possible that oil could be leaking where the case halves bolt together? Also, has the address changed for the online manual? This is a 73 GT 750. Thanks,
tc
When in doubt, smoke it out!
73buffalo
The Manual
Post by 73buffalo »
The online manual site did change. The ~ in front of mraxl is no longer there. Here is the current link:
http://www.3cyl.com/mraxl/gt/index.htm
Re: Oil leaky
TC wrote:Oil leaking somewhere in the front of the engine, below the exhaust ports. Does not seem to be goo and dribble from the exhaust, but seems to be injection oil consistentcy. Could this be something to do with the sris system? Is it possible that oil could be leaking where the case halves bolt together? Also, has the address changed for the online manual? This is a 73 GT 750. Thanks,
tc
It wouldn't be leaking from the split in the cases (if it's still running), but it could be from a leaky fitting or hose in the SRIS system.
TC
Post by TC »
I am hoping that it is one of the hoses, I have remove the exhaust and drained the coolant so I can get in there and clean it real good... Some, I have noted , have blocked off the system, how is that done?... Thanks for the updated address on the manual.
tc
Re: Oil leaky
TC wrote:Oil leaking somewhere in the front of the engine, below the exhaust ports. Does not seem to be goo and dribble from the exhaust, but seems to be injection oil consistentcy. tc
I expect you have already ruled this out, but sometimes you do see this as a result of a leaking exhaust gasket seal. If its on a centre pipe, then it can appear to be SRIS oil - till you wash it all off and double check where the oil is coming from, sometimes its tough to tell.
