Hey guys, was wondering if you knew of any stock rims from any bikes that have the same axle size as the t500 rear rim, and could also use disc brakes? I'm getting kinda tired of the drum brakes, and if I could find one that has disc brakes, I could modify a rearset for the master cylinder/brake lever...
also need to know of any stock front rims that could help with the same issue, I understand the GT500 forks would work and those have a front disc, just trying to avoid all the fabrication stuff....
thanks a lot
zac
T500 brake help
- zrs1919
T500 brake help
pft.
