Suzuki T20 Front Brake
Posted: Fri Apr 16, 2021 5:38 pm
Greetings all,
Does anyone know what to do if the front brake is dragging and will not adjust. Since it is a dual cam front brake I backed the adjusting rod all the way off and still have a dragging brakes. I was thinking of removing the front lever pin to release the adjusting rod, then remove and reposition the front cam lever on the front cam shaft to release the internal shoe, then reconnect the adjusting rod and adjust. Might I be causing any unnecessary work by doing this versus removing the whole brake assembly, adjust everything and then reinstall the brake? By the way adjusting the brake cable does not help.
Secondly, I adjusted my carbs today then shut the bike down and disconnected the battery connection wire. Subsequently I wanted to check something else, so I turned the key on and fired the bike up. I noticed the neutral light was very bright and flickering some. So I shut it down. I then notice the battery was disconnected. I cannot figure how it started, it acted like a magneto, but the book says it has an alternator. How did it start without the battery connected? Any ideas anyone?
ettore
ettore
