What rotors will bolt up to a GT 550/750 Hub
Posted: Fri Apr 23, 2010 10:19 am
by durgam
In my never ending quest to make an old bike New(er) again, Im looking to upgrade the front brakes ( to SV or Katana) rather than design and make a new caliper.
My Katana Rotors are 5 hole, and I noticed that GS1100/1000 rotors are 6 hole. Who can tell me if they will bolt up? It doesnt have to be a Suzuki rotor either.
Stock GT rotors are too thick to use with my Katana Calipers, let alone spacing the rotor out and an adapter plate to mount said caliper.
Posted: Fri Apr 23, 2010 4:13 pm
by pjmcburney
You're not alone on this quest...
GS, GSX rotors will not only bolt straight up, but (I think) will work with either caliper - GT or GS/GSX.
Like this:
There was also mention made of a Kawasaki rotor that fits as well, do a search on the site and see what turns up?
Paul
Posted: Fri Apr 23, 2010 5:06 pm
by Suzsmokeyallan
This type bolts up directly as well and has the floating rivets and slots.
A slightly better design than the spiral slotted 'Y'spoked previous version.
http://cgi.ebay.com/ebaymotors/SUZUKI-G ... ccessories
Posted: Fri Apr 23, 2010 6:40 pm
by advant63
the caliper mounts have a different bolt centre so you'll have to keep the gt calipers.
i have dual gt calipers and holy rotors on gs wheels using gs750 master and hoses.
it's acceptable for my purposes but i'm sure gs rotors would improve it alot.
Posted: Sat Apr 24, 2010 7:27 pm
by Willie
I'm in the process of mounting a pair of CBR600 rotors and SV650 calipers on my GT750. I just began taking measurements today and it "appears" that I'll have to make a 1mm thick sleeve for the hub and redrill the rotor mounting holes. The difference weight is impressive.
Willie
Posted: Mon Apr 26, 2010 8:31 am
by rbond
So, does this mean that a GS rotor might just as easily work on a GT500 too?
Posted: Mon Apr 26, 2010 10:09 am
by Barry S.
rbond wrote:So, does this mean that a GS rotor might just as easily work on a GT500 too?
Probably, I put one on a '77 GT380.
