Hey guys, I have recently bought my first bike and have been trying to repair it. I have a 1973 Suzuki TS400 K Apache, and have recently have been trying to get the carburetor clean and working. However, no matter what I do, there always seems to be fuel coming out of the overflow on the back side of the bike. I have tried adjusting the float level to no avail, and this specific carb is pretty hard to come by. Does anyone know why it wont stop overflowing? Also, does anyone know know if a Mikuni VM35mm, would do the job? i was thinking about buying one but i would prefer to just fix the one I have. Any help would be appreciated.
Thanks,
Joe
1973 Suzuki TS400 Carb problem
- Suzuki 2-Strokes: 1973 Suzuki TS400 K Apache
Re: 1973 Suzuki TS400 Carb problem
Hello Joe,
If the carb is overflowing it is most likely the Needle Valve Assy is not sealing. This could be due to dirt preventing it sealing or it's plain worn out. I just checked on the Alpha Sports parts list and they list it as available (Part No. 13370-16600) although at a hefty $56.06. I would unscrew the assy. from the carb (it comprises two parts) and give it a thorough cleaning first .
To see what you dealing with check out the Alpha parts list, it is item #14 shown on the 1973 Dual Sport Model/TS400K (Apache)/Carburetor Parts diagram
http://www.alpha-sports.com/suzuki_parts.htm/" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
A fairly common problem on carbs that have not seen any use for some time.
Is the float damaged? They can rot and fill with gas, which prevents them from floating.
I’ve had a sunken float — a crack in the float causes it to fill with gas and sink.
Crud or a solder repair can cause the float to be heavier than it should be.
A dent in a float can cause it to not float as expected.
An ill-fitting float bowl gasket can interfere with the float motion.
A worn of dirty needle valve can interfere with its operation.
Suzuki used standard Mikuni needle valves. Its a lot cheaper to get them using the Mikuni part #.
You can figure out which one you have via: http://jetsrus.com/needle_valve_float_b ... ikuni.html
Thanks guys, looking at jabcb's post, i think i might buy a new one, but im not sure which version it is, what do the 1.5, 1.8, and 2.0 mean?
