TS125C Project
Zunspec4
TS125C Project
Post by Zunspec4 »
I had this posted on the old Forum so I thought an update was due.
As bought from your favourite web auction house
The real truth :D
The start of the re-build
Engine in
Rolling chassis
Sorting the wiring at the moment, which begs a questioin. The parts list at Alpha Sports (TS125C 1978/79) lists a a voltage regulator but I can see no reference to one on the circuit diagram (from genuine Suzuki workshop manual). Any help welcomed, never had A.C. lights before.
Cheers Zunspec
[/img]
H2RICK
Country: CANADA
Post by H2RICK »
What Suzuki may call a "voltage regulator" we would know as a zener diode.
IIRC, those tiddlers just use a little black box with a diode in it up near the steering head somewhere. It's about 1" square, IIRC, with one or two wires coming into it and it's got a through bolt grounded to the frame.
GT550A Mint & Original
MBD Sufferer
Zunspec4
Post by Zunspec4 »
Hi Rick,
I think I worked it out. The US market version of the TS125C circuit diagram shows a "Voltage Regulator" but the UK/European one doesn't. I think you are right though the V/Reg. its a simple Zener Diode type. I wonder why us old world types don't get a V/Reg. someone on a back hander from the bulb companies :D
If it is useful to anyone I "colourised" the TS125C circuit diagram (also one for the TS125ER, which I did by mistake cos I scanned the wrong page :D )
TS125C
http://farm4.static.flickr.com/3620/352 ... e702_o.jpg
TS125ER
http://farm4.static.flickr.com/3568/352 ... e845_b.jpg
Cheers Zunspec
Zunspec4
Post by Zunspec4 »
Hi all,
An update on my TS125 project. Got it running today and had a little play up and down the road. A perky little power band, I can see my gear changing technique getting quicker for this one.
Image Image Image
Lots of fettling still needed but basically now a runner :D :D :D
Cheers Zunspec
It looks great!!! Nice work.
H2RICK
Country: CANADA
Post by H2RICK »
She's a beaut !!!
It is strange to me why the UK got the low fender version.....on a dirt bike.
Maybe they decided that it was a street bike with offroad pretensions ??
In North America all the TS's from ~1970 onwards got the high plastic fendered version. There's nothing worse than to have the front wheel stop turning because of mud-cloggage when you're going down a long hill......Ouch !! Arse over tit into the poison ivy !!! Or the bog..... :lol: :lol: :lol:
MBD Sufferer
rbond
Post by rbond »
Not one to nit pick, but I hope you are going to re-route the clutch cable. I don't think it will last too long laying against the exhaust...... That is however a great restore on the bike. Looks better than new!
Zunspec4
Post by Zunspec4 »
Thanks for nice comments guys. I must admit I am well pleased with how it has come along.
As pointed out a close fitting chrome f/mudguard isn't exactly what you want on an off-roader but it probably was aimed at the UK on-road learner market (Enduro themed). Actually there were not a lot of places you could go off-road in the UK even in the 1970s, and thats reduced by 80% since then as the Bl%dy Ramblers Association have lobbied to get what is there re-classified for pedestrian use only. Still, I shall enjoy buzzing it down the smaller of the Highways & Byways of jolly Olde England, still lots of (semi) tarmac country lanes available :D .
I shall keep an eye on the clutch cable although according to the Suzuki manual it's in the right place (does not actually touch the exhaust)
Cheers Zunspec
PS: The next project is going to be a GT500 based Flat Tracker, I'm fed up of chasing genuine/NOS parts either from Suzuki or the Mr Millers of this world. The freedom to Mix an Match cheaper parts from other bikes is appealing.
Zunspec4
Post by Zunspec4 »
rbond wrote:Not one to nit pick, but I hope you are going to re-route the clutch cable. I don't think it will last too long laying against the exhaust...... That is however a great restore on the bike. Looks better than new!
Thanks to rbond - I was prompted to look a little closer at the clutch routing. What I then noticed is that there is a wire clip/guide secured by the front heat shield screw. The clutch cable runs through the ring of the clip ensuring it does not touch the exhaust.
The next question is, does anybody have a Part No. or detailed photo of this wire clip/guide.
Thanks for any help
Cheers Zunspec
two-stroke-brit
Suzuki 2-Strokes: gt750
Post by two-stroke-brit »
what a great restore of a little dualsport. :)
1973 SUZUKI GT750K.=SOLD
1982 HONDA CB900F =SOLD
1982 YAMAHA RD350LC.
1985 RZ350N
H2RICK
Country: CANADA
Post by H2RICK »
Zunspec, lots of 70's dirt bikes used such a little clip/ring gizmo with the wire bent into a circle at either end. My '77 PE250 had one with the smaller circle attached to the top of the cylinder head with a 6mm screw. The larger circle was where the clutch cable went through. Take a look at a wrecker's yard in the dirt bike section. You'll see lotsa them on various bikes. The ones with the
larger diameter wire cross section are more durable.
MBD Sufferer
Zunspec4
Post by Zunspec4 »
Hi Rick,
I found a suitable clip amongst the miscellaneous bit's an bobs I had laying around. Not the correct part but it looks as if it will do the job
Cheers Zunspec
PS: It's not really a brown exhaust in fact it has had a "ceramic" coating in pure black. Must be an affect of the camera setting and flash.
How it should look:
H2RICK
Country: CANADA
Post by H2RICK »
Clip looks "factory" to me, Zunspec. :D
Keep an eye on it, though. They ARE prone to vibration cracking/self destruction. :wink:
MBD Sufferer
