520 front sprocket for T500
datsunrides
Suzuki 2-Strokes: T500
Post by datsunrides »
Does anyone know if there is a 16T 520 front sprocket available for the T500? I have seen where the early RM250 sprockets cross but those seem to max out at 15T.
Re: 520 front sprocket for T500
Going an extra tooth on the gearbox will turn your top gear into an overdrive and it'll be a pig in traffic.
If you really want to gear it up, you could get a 2 tooth smaller rear sprocket.
datsunrides
This isn’t for a original T500. I am dropping the motor in a GS500E chassis and it seems that the OEM 39T rear sprocket is the smallest available without getting a custom one. Just trying to get the gearing back closer to the 15/33 gearing of the T500. The 15/39 gearing won’t be horrible since this will most likely never see highway speeds for any prolonged periods but I also don’t need a buzz bomb either. If a 16t front is not in the cards and the 39T rear is not a good match once I get her on the road then I can look at a custom sprocket.
Might be worth while looking at this thread in another forum.
https://www.kettleclinic.co.uk/kcforum/ ... ilit=Gs500
A good friend built it and it'a very good looking bike.
datsunrides
Alan H, thanks for the link. That is nicely done. I highly doubt mine will ever get done to that level. Mine was, I assume, a track day bike at some point as it has had a gsx600 front end swapped on, clip ons, and some safety wiring. I am assuming he is/was running the 15/39 gearing that I am trying to raise based on his comment on the low gearing. I am probably going to modify my down tubes a little different but the way he did it is very clean.
