Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Thu May 24, 2018 12:28 am
Post new topic Reply to topic  [ 5 posts ]
Author Message
 Post subject: turn signal relay.
PostPosted: Sun Oct 13, 2013 6:42 pm
Offline
Country: U$A
Bikes owned: 71GT750,75GT550,68cobra,69titan,86RM,82GS850
gt750j
my signals (winkers,blinkers,indicator lights) will light up with the switch but will not blink.
i replaced the relay with a cheap one from pepboys and now the lights still light up with the switch but my tail light blinks.
the relay has 2 poles. the old one had 2 poles and another black wire coming off of it?
i have the diagram, i couldnt really figure this out. im sure its pretty simple. there is some re wiring that happened that i have been slowly trying to rectify.
Top
 Profile
 Post subject: Re: turn signal relay.
PostPosted: Mon Oct 14, 2013 11:27 am
Offline
Bikes owned: GT750(Jx3,L,M,A,B),T500
Sounds like something is crossed somewhere for sure - was the wiring in the headlight bucket fairly original, or modified ? 8)
_________________
Top
 Profile WWW
PostPosted: Mon Oct 14, 2013 12:44 pm
Offline
World Superbike
Bikes owned: GT550s GT750 GSX1400 and lots of spares
Orange to the indicator relay is power. Light blue goes to the centre terminal of the indicator switch. Green from indicator switch goes to right indicators, black from indicator switch goes to left indicators. There are two double connectors in the headlamp - one green and one black, the two wires from the indicator bulb in the clocks go to these terminals. The extra black wire was an earth. make sure that the indicator relay is fastened securely to earth. All bulbs must be normal filament type NOT LED.
Top
 Profile
PostPosted: Mon Oct 14, 2013 9:43 pm
Offline
Country: U$A
thank you i got it squared away with some help. its tough trying to fix a butchered harness!
Top
 Profile
PostPosted: Tue Oct 15, 2013 5:45 am
Offline
Bikes owned: 75- GT 550 / 76- GT 750
You're correct, it is. With very little know how, patience and 50-60 bucks you can remanufacture a new one. I have also learned recently. That no matter, if you snip the ends of the wire to do away with corrosion there. Replace connectors, etc. The wiring, within the sheeth is still oxidized very well. The cooper after all has been exposed to air and moisture for nearly 40 years. For those reasons, replace much of it as possible with new. At the very least, clean the copper and connectors. Apply electric grease.
_________________
Top
 Profile
Who is online
Users browsing this forum: No registered users and 5 guests
Search for:
Jump to:
Suzuki2Strokes.com
