T500 tuning question
br549smith
Country: usa
Suzuki 2-Strokes: t500
Post by br549smith »
Have a 1971 that when hot pings during cruising speed and decal. Point gap 14, timing is set correct, running 30 pilot and 150 main and needle is set at top notch. Have foaled plugs in town riding but when riding open throttle it appears to be lean looking at plugs. Tried 25 pilot bike didn't run well at all. Stock air box stock exhaust.
desmocat
Suzuki 2-Strokes: T500, TS250, B105P, GS250T
Re: T500 tuning question
Post by desmocat »
You might want to check for air leaks carburetor to manifold boots and boots that seal the throttle cables to carbs. I had a similar situation and the problem was the carb top boots.
Ralph Spencer
Spencer Motoworks LLC
Southfield, MI USA
www.spencermotoworks.com
AHRMA #798
LexPaul
Post by LexPaul »
I have a 1970 model T500 and I run only 100% Pre Gas, high octane 92. Runs like a champ and never a ping. Thanks
1970 Suzuki T500 Titan Twin
1971 Yamaha HS1B 90cc Twin
tricky1962
Country: United Kingdom
Suzuki 2-Strokes: T500J
Post by tricky1962 »
desmocat wrote:You might want to check for air leaks carburetor to manifold boots and boots that seal the throttle cables to carbs. I had a similar situation and the problem was the carb top boots.
Those carb top boots need to be airtight? I would have thought the amount of air leaking there wouldn't affect mixture.
Can anyone else confirm that these are critical before I shell out my hard earned cash on some new ones?
