b7evx plug question?
- Country: U.S.
- Suzuki 2-Strokes: 1974 gt750, 1963 superhawk
well, im in the process of putting the newtronics kit on the bike, but before I did that I found a set of ngk b7evx platnum plugs for the bike, before I had put them in I had regular b7es plugs, and i had been adjusting the oil pump to its max to see if the bike was getting oil, well I foulled the plugs so i would say yes its getting oil, so then I put the b7evx plugs in and adjusted the oil pump to the normal setting and now the bike smokes? what the hell? I check the plugs and they are black like they are to rich except the far left plug, its lean? I will check the carbs but it was not like this when i had the b7es plugs in, so the question is,,,,when i got the b7evx it said they were non resistor plugs so I got them ( i have stock plug caps) and now the bike smokes? and plugs look rich? but with the regular b7es the plugs look lean? what the hell? any thoughts? I will look at carbs but like i said it looked lean with b7es and now rich and smokes with the b7evx? and i checked it with both plugs without messing with the carbs, so i guess its the plugs? are they colder than the b7es? I know the 7 is the heat range but this is weird?
Re: b7evx plug question?
It's hard to accurately gauge richness / lean-ness with brand-new plugs, they take a while to get a colour. Also, it will be smoking because it's firing the mixture and cleaning all the oily crap out of the cases, not fouling the plugs ...
An explanation of the plug names is here: http://www.ngksparkplugs.com/docs/tech/ ... _plugs.pdf
The B7EVX are discontinued. Suggest you buy some spares if you decide you like them.
The B7EV is similar -- might also consider getting some spares of these since they are discontinued.
- Country: U.S.
Thanks for the info!, I was wondering if any of you had tried the b7evx and if so did you like them? i ran the bike for a few miles and she started running funny then i pulled the plugs and they were black, very black so maybe theres another issue going on?, well when I finish the newtronics kit and test run i will report back, thanks for the help.
- Country: U.S.
Interesting results. the advantage of a fine wire plug is that it is less likely to foul than a standard wide electrode. I use BR9EIX Iridium plugs with a slightly non-standard set up. Mine runs very high compression and a DYNA S ignition and a relay to make sure that no volts are lost going through the stock wiring and connectors.
Big fat blue sparks and no hint of a misfire even when the cases were half full of oil from leaking check valves. Maybe a stock ignition system cannot generate sufficient voltage to fire a fine wire plug consistently.
- Country: U.S.
That may be true, Richard. I noticed much easier starts, better idle, etc. On my bike though, it's very hard to keep them clean and my pump is turned down very far. Im going to try them on the 750 being I will have aftermarket coils on it and see how they act.
