Newtronics ignition
- Country: U.S.
- Suzuki 2-Strokes: 1974 gt750, 1963 superhawk
Newtronics ignition
I just replaced my points and condensers , I checked the timing with just a timing light, it was off , anyway I have the timing marks lined up withe the mark on the case and it seems to run good except right cylinder was pretty far off, it's on now but it kinda sounds like the timing is still off, but it runs good. I guess I'll have to get the dial gauge,. Then I saw a newtronic ignition for sale and I bought it, and crap it's expensive! I hope I did the right thing buying it, My question is how hard is this to set up? Do you still need a dial gauge? To set timing? Or can you use the timing light?, also has anyone had problems with these? And is it set one cylinder and the other two are automatically done like some other systems? Thanks for the help, I'm just going to run the bike till it doesn't want to run anymore before I tear it down, hopefully by then I'll be doing better.
Re: Newtronics ignition
Most of the guys that have fitted Newtronics systems seem to like them. They have some adjustability for the other two cylinders IIRC.
I prefer to set timing initially with a dial gauge sand check the timing marks to make sure they are close enough to use, but I run a lot more compression in my motors and need to get the timing spot on.
Timing with that system should be set and forget, where points are from the old school of rinse and repeat.
