oil pump on gt380...and other migraines
Re: oil pump on gt380...and other migraines
Hi Martin , here is a board members site with lots of the info you will need for your restoration http://www.oldjapanesebikes.com/mraxl_G ... index.html" onclick="window.open(this.href);return false; and yeah there are ways to check the oiling system and while you have it apart might as well clean out and check the one way inline valves in the injector lines also described on the site
It takes forever kicking it over. Here's a simple approach.
1 pinch off oil feed line
2 Remove oil pump
3 Fill oil lines with a simple hand held oil can or syringe - use oil that's a different color to what's in the tank
4 replace pump
5 un-pinch oil line
6 bleed oil pump (there's a screw at the top, loosen it until oil seeps out and replace it)
7 run bike around the block and see if oil from the tank has replaced the oil in the lines (remember the tip about different colors? That's why).
If that doesn't work, or only some of the lines changed color, you will have to remove the plastic feed manifold aka Octopus and clean it out with alcohol. Do not use high air pressure from a compressor - that will destroy the check valves.
Clean out the banjo bolts and force feed oil through the drillings in the crankcase with your oilcan or syringe to be 100% sure that nothing is blocked. Then repeat the trick to change oil color by riding around. It's magic when it works.
2 Remove oil pump
4 replace pump
5 un-pinch oil line
