If you're interested in any of these parts just make me an offer.
I wound up with a bunch of spare parts while trying to get my 74 gt550 running. Some of these parts might not be salvageable, but some I believe are. Mostly, I didn't want to throw these out if someone here can make use of them. I have no use for them.
All carb bodies have needle jets, and some have the main jet washer. No idea if they're useable.
* 6 carb bowl bottoms
http://www.freeimagehosting.net/bdr8p" onclick="window.open(this.href);return false;
http://www.freeimagehosting.net/qaqz6" onclick="window.open(this.href);return false;
* 2 left carb bodies (one with frozen throttle valve, jet needle, throttle valve rod, starter plunger)
http://www.freeimagehosting.net/m481e" onclick="window.open(this.href);return false;
http://www.freeimagehosting.net/9keos" onclick="window.open(this.href);return false;
* 2 middle carb bodies (one with frozen starter plunger)
http://www.freeimagehosting.net/upyic" onclick="window.open(this.href);return false;
http://www.freeimagehosting.net/lra8l" onclick="window.open(this.href);return false;
* 2 right carb bodies (one with frozen throttle value, jet needle, throttle valve rod)
http://www.freeimagehosting.net/v8s8m" onclick="window.open(this.href);return false;
http://www.freeimagehosting.net/yvljp" onclick="window.open(this.href);return false;
* 6 floats
http://www.freeimagehosting.net/md857" onclick="window.open(this.href);return false;
http://www.freeimagehosting.net/ler1z" onclick="window.open(this.href);return false;
* 6 throttle valve springs
http://www.freeimagehosting.net/wqs2k" onclick="window.open(this.href);return false;
* Assorted carb parts
http://www.freeimagehosting.net/bw6rr" onclick="window.open(this.href);return false;
** 6 valve seats
** 6 needle valves
** 6 main jets (not sure which sizes, but all are likely stock, likely 2 complete sets)
** 3 pilot jets (likely stock size)
** 4 throttle valves
** 6 float dowels
** 3 jet needles
** 4 throttle valve rods
** 3 throttle valve adjust nut sets (top and bottom, 6 total pieces)
** 2 starter plungers
** 3 jet needle set plates with screws (2 each)
** 2 used bowl gaskets
** 2 used carb body o-rings (top)
* Assorted carb unit parts
http://www.freeimagehosting.net/lskp4" onclick="window.open(this.href);return false;
** Top plate screws
** Starter lever spring, ball bearing, screws
** Throttle shaft keys
* Top plate, cracked in half, misc parts attached
http://www.freeimagehosting.net/9mvdd" onclick="window.open(this.href);return false;
http://www.freeimagehosting.net/rl2oq" onclick="window.open(this.href);return false;
* Top plate, good condition, misc parts attached
http://www.freeimagehosting.net/hkvj5" onclick="window.open(this.href);return false;
http://www.freeimagehosting.net/m1j1y" onclick="window.open(this.href);return false;
* 3 intake tubes, 1 starter plunger lever
http://www.freeimagehosting.net/lqdlu" onclick="window.open(this.href);return false;
* Throttle cables
http://www.freeimagehosting.net/kpb8c" onclick="window.open(this.href);return false;
* 4 throttle valve boots
http://www.freeimagehosting.net/j8yuf" onclick="window.open(this.href);return false;
* Right cylinder - light surface rust inside cylinder from exposure while off bike. Slightly bent fin. Dent in fins where an improperly installed kick starter wacked agains the cylinder. Since this was graciously given to me for the price of shipping alone, I'm happy to do the same for anyone who wants it. Should be around $11.
http://www.freeimagehosting.net/8x7ko" onclick="window.open(this.href);return false;
http://www.freeimagehosting.net/8rxau" onclick="window.open(this.href);return false;
http://www.freeimagehosting.net/r6ojz" onclick="window.open(this.href);return false;
* 4 brand new oil tank caps - I needed one and accidentally bought a pack of 5, somehow. These are free. I figure I can just drop them in an envelope.
Andy
1974 GT550 parts (carb stuff, right cylinder, oil tank caps)
Re: 1974 GT550 parts (carb stuff, right cylinder, oil tank c
ALL PARTS SOLD
