T500R piston rings
joewillybob
T500R piston rings
Post by joewillybob »
Putting new rings in my T500. Looks like I can reuse the old pistons. The old rings are appox. 2mm wide. They also look like each ring is made of 2 pieces sandwiched together. My shop manual doesn't give the specs on ring end gap. Also, what is the Suzuki part # for std. size rings. My understanding is that there are 2 different types of rings[thicker and thinner] that were used. Thanks in advance.Also, my pistons are the type with several grooves below the ring lands.
GT500Andy
Country: Netherlands
Suzuki 2-Strokes: T500R, GT500A, TS400, V strom black rhino
Re: T500R piston rings
Post by GT500Andy »
These are the correct rings keystones ring, gap 0.008-0.40 in. if the pistons are within tolerance I would use first oversize rings and gap them down in the cylinder this will give you a better compression and fit in the worn cylinders
Andy
GT500Andy
Post by GT500Andy »
May be in the UK
parksie
Suzuki 2-Strokes: Suzuki t500 69,71,73, Gt500 76
Post by parksie »
Dear Oh dear :shock:
1969 T500
1973 T500
1971 T500 (being restored)
1976 GT500 (being restored)
2012 Ninja 650
