Possible source for new oil line check valves.
lrutt
Post by lrutt »
As I had mentioned in my opening post, Seadoo used check valves on their oil injection system on their 2 stroke PWC's.
Here is a link showing the system. Look at item 18. This is the valve. Banjo type like the suzuki uses. Possible it could be spliced into the lines replacing a defective original.
Just a thought for someone who is in a bind.
http://partsfinder.onlinemicrofiche.com ... 3&A=31&B=9" onclick="window.open(this.href);return false;
2004 HD 1200C
2001 Duc M900
2001 Hon XR650L
1994 HD Heritage
1978 Hon CB750 w/ sidecar
1977 Guzzi 850 LeMans
1976 Hon CB750K
1965 Hon 305
1973 Nort 850
1971 Tri Trophy 650
1970 Hon CT 90
1970 Tri Tiger 650
1970 Suz T250
1973 Hon Z50
1971 Yam RT1
Re: Possible source for new oil line check valves.
Interesting - the bolt size (item 19) is the same size so it looks promising. 8)
lrutt
Post by lrutt »
If nothing else, there are TONS of old non-running Seadoos out there with these things on them. Could pick them up for chump change I suspect.
2004 HD 1200C
2001 Duc M900
2001 Hon XR650L
1994 HD Heritage
1976 Hon CB750K
1965 Hon 305
1973 Nort 850
1971 Tri Trophy 650
1970 Hon CT 90
1970 Tri Tiger 650
1970 Suz T250
1973 Hon Z50
1971 Yam RT1
