rebuild T500 oil pump
jasper
Post by jasper »
Hey guys.
I am looking to replace the upper and bottom seal to my T500's oil pump. The bottom seal looks like it will just pop out with a hook; the top one I'm not so sure about. Do I need to remove the bearing to remove the seal? Has anyone done this that can give me some pointers?
thanks
parksie
Suzuki 2-Strokes: Suzuki t500 69,71,73, Gt500 76
Re: rebuild T500 oil pump
Post by parksie »
It's been a while since I did mine but if I remember correc tly the three screws on the top need to come off then that shaft comes out so you can replace both oil seals. there is also a "square type o ring inb the top as well"
hope that helps.
1969 T500
1973 T500
1971 T500 (being restored)
1976 GT500 (being restored)
2012 Ninja 650
jasper
Post by jasper »
Good to know that the shaft needs to be removed. I'll try that, thanks
