Clutch removal suggestions, X-6
barko1
Post by barko1 »
Looks like a 26mm nut that holds the clutch basket on, of course I don't have one :x My manual says to use the special holder to keep the crank from moving, would an impact wrench work? I'd rather not remove the head right now, just the clutch :) Thanks for any ideas.
John I aka Barko1
Concours 1400
DR650
KDX200
Norton Commando 850
Suzuki X-6 Hustler Scrambler (in pieces)
Suzuki GT750 Buffalo (TBD)
Re: Clutch removal suggestions, X-6
To lock the motor to remove the clutch nut, stuff a rag between the crank gear and primary gear. Reverse rag direction for tightening. 8)
barko1
Post by barko1 »
Coyote wrote:To lock the motor to remove the clutch nut, stuff a rag between the crank gear and primary gear. Reverse rag direction for tightening. 8)
Thanks!! That was easy. found a 27mm socket and pulled it off. 1 step down, 1000 to go :D
John I aka Barko1
Concours 1400
DR650
KDX200
Norton Commando 850
