GT750M starter motor replacement
pennell
Post by pennell »
Mine just crapped out after taking it out of winter storage.. Must have been on its last limbs. Any insight on if replacing it is tricky? It seems pretty accessible. Should I get a new starter or just rebuild mine?
Any help is greatly appreciated.
Re: GT750M starter motor replacement
And you are certain it isn't the starter relay that's the problem ?
pennell
Post by pennell »
aha you bring up a very good point that I think is more than likely the culpret. The starter worked great before I stored it.
Or a bad connection at the button?
pennell
Post by pennell »
I will do some investigating and let you know what it is..
Check that your brushes are not stuck or broken or worn past limit. According to Motor City PS the brushes are still available for both the Mitsubi and the Nippon Denso starters.
