fiberglass fuel tank mounts
I have a fiberglass seat and tank that was a dealer installed option an early t20's. I'm installing them on a T350 cafe project. The front of the tank is held down with a rubber strap similar to the strap that holds the poly oil tank. Anyone have any ideas where I might find one or something similar? Thanks.
Re: fiberglass fuel tank mounts
I'm looking for some also, but the main thing is if you are using street gas, and there is any ethanol, you will need to coat the tank with Caswell 2 part tank coating, or it will eat the resin and goop everything up. Don't scrimp, use the full quart, even though most will drain out, a pint will not cover a tank, it's too thick......joewillybob wrote:I have a fiberglass seat and tank that was a dealer installed option an early t20's. I'm installing them on a T350 cafe project. The front of the tank is held down with a rubber strap similar to the strap that holds the poly oil tank. Anyone have any ideas where I might find one or something similar? Thanks.
thanks for the tip. already have the caswell sealer,just haven't used it yet.
