Wiring?
GreenMachine
Wiring?
Post by GreenMachine »
Hey guys,
Went out to the shed last night to sort through my boxes of bike, noticed that some mad bastard has gone through the entire loom of my T500R, cut out the plugs and soldered the wires together.
Is this an accepted mod? Anyone know a good reason for it? Should I travel back in time and punch this person?
NH
'71 T500R
'72 Plymouth Scamp
ColumnShift Media
elbert
Re: Wiring?
Post by elbert »
I can understand that someone would do it, but I don't think it is the best modification. I have had two connectors melting and stopping me from going any further. Both times was in Germany quite far away from home, luckily I always bring with me a bag of mixed items so I was able to cut out the melted connector and splice the wires.
Both the times was on my GT750, never had that problem on the T350, maybe because I cleaned and inspected all the connectors on that one, or maybe the generator on that one just isn't up to the task of melting anything...
Planing to replace the wiring on the GT750, think you should considder the same, would probably be cheaper than to source new connectors.
GreenMachine
Re: Wiring?
Yeah, I plan to go to a modern regulator/rectifier, LED indicators/taillight, electronic ignition etc, so it will probably be worthwhile rewiring everything while I'm going. Hopefully I can sort out the factory spaghetti inside the headlight bucket as well - surely most of it is unnecessary.
'71 T500R
'72 Plymouth Scamp
ColumnShift Media
two-stroke-brit
Suzuki 2-Strokes: gt750
Re: Wiring?
Post by two-stroke-brit »
you can get a nice reasonably priced solid state regulater/rectifier combo at.
http://www.oregonmotorcycleparts.com" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
and i fitted newtronics iggy ( points chalenged :oops: ).
with great results.(fit and forget.)
cheers mark
1973 SUZUKI GT750K.=SOLD
1982 HONDA CB900F =SOLD
1982 YAMAHA RD350LC.
1985 RZ350N
krwalsh
Re: Wiring?
Post by krwalsh »
In general soldered connections should be avoided. The solder wicks up the wires, and creates stiff sections next to pliable sections, and you will have them fatigue, crack, and you'll have broken and intermittent connections.
Well done crimped connections are much more reliable.
Kevin R. Walsh '75 Suzuki GT-250 Cafe Racer
