Want to mount your calipers 'behind' the fork legs but hate the way the logo cutout now points at the moon? Here's what I did to overcome the problem.
I needed some Bondo to fill in the tank recesses anyway so I put it to use here as well. 2-3 applications and some vigirous sanding and the logo window is gone. They were then shot with Dupli-Color high temp silver.
The tank recesses on the other hand were not so easy. I bet I spent 20 hours the get the contour just right. I applied Bondo 6 or 7 times and did the final work with primer putty.
If you ever attempt to fill in the tank recess, here's a hint. Take your plastic spreader and heat it under a lamp. When it's warm, create a curve in it with your hands. This way the filler stays proud of the cutout and is eadier to work down.
Good looking set of calipers, Coyote. Interesting colour choice.
GT550A Mint & Original
MBD Sufferer
make sure you wipe the brake fluid off those quickly, i painted a caliper on CB550 with that stuff and the brake fluid eats it very easily and quickly, make sure you have no leaks either, they will show up in the form of bubbled paint
