New T20 problem
New T20 problem
Took the bike for a test run this morning. I have noticed at times what seems to be a loss of power but today it just died 1.5 miles from my house. Pushed it back for a ways and tried it again. Started up and I took off for just a short time and died again. It's like I just turned the key off? Seems to start ok once it's cooled down. Any hints? Thanks
Doug
- advant63
- Country: canada
- Suzuki 2-Strokes: m12 or50 a100 s32-2 s32-2 t250 gt250 t500r
Big problems I fear. What I didn't say in the initial post is that I notice a significant knock from the right cyl. Can even feel it when my hand is on the muffler. I think it is related to the lack of oil to that cylinder and the pump problems I have posted before. Smokes nicely out the left pipe but very little out the right. Have tried 2 oil pumps and same air problem persists on that side. I think it runs ok when cold because the piston has contracted but when running awhile, it swells and seizes the engine due to lack of lube. I am away from home for a couple weeks so won't be able to work on it til I get back. Going to take it apart as far as I need to in order to find the problem. May have to get a new piston and redo the cylinder. Won't know til I get in there. I think the check valve oil passage into the cylinder may be the culprit. Oh well, will keep me busy for awhile longer.
Doug
In your first post you said "It's like I just turned the key off?" A seized piston would feel more like you hit a wall and it tends to flip your butt over the handlebars.
The knock could be nothing more than extreme pre ignition. If that's the case and you run it that way, you're headed for a holed piston. So while you are purchasing new condensors, pick up a new set of points too. Then re gap and set te timing again.
