T500 timing
Monkey man
Suzuki 2-Strokes: T 250 t500 gt 550
T500 timing
Post by Monkey man »
Good evening all
Have been out on the t500 recently and all is well but I’m going to strobe the timing soon .can anyone advise what revs I should be running when aligning the strobe marks?
karl pa
Country: us
Suzuki 2-Strokes: GT
Re: T500 timing
Post by karl pa »
Any, there is no advance on timing, so you can check any rpm. I check at idle.
joethebike
Suzuki 2-Strokes: Suzuki T20-250-350-500
Re: T500 timing
Post by joethebike »
When I strobe my T350 the timing retards a mm or so on the rotor index mark as the revs increase. I have checked the rotor mark with a dial gauge to prove it correctly aligns at the timing distance before TDC.
1982 Honda CX500 EC 275,700km
2005 Suzuki DL650 151,500km
Monkey man
Re: T500 timing
Hi guys back again after checking the timing marks using a dial gauge and happy to report the timing lines on the crank were spot on . So I set the timing first using a bulb arrangement linked the points and earth and then with the strobe to verify ok . However before this when setting the points gap to the recommended gap I couldn’t get the points to open anywhere near the timing marks. The only way I could was to reduce the points gap which allowed me to set up on the marks.
The bike starts and idles fine but out on the road is slow to pick up across the rev range and in every gear - a bit like turbo lag in a car
Any ideas where and what to look at ?
markush
Country: Germany
Suzuki 2-Strokes: GT250/380
Re: T500 timing
Post by markush »
Monkey man wrote: Sat Oct 12, 2024 9:16 amThe only way I could was to reduce the points gap which allowed me to set up on the marks.
Probably worn out ignition contact sliders. Use new contacts.
If the ignition is OK so far, this sounds more like a carburetor issue.
