Difference between Late and Early model Cylinders....
- Jughead
- This IS the real me!!!
What are the Port Differences for the Early and Late model T500 Cylinders? All I can see is the Big AZZ Bridge that splits the Intake in the Late model ones.I know the Later ones ran the longer intakes.I found a set of Later Model ones in my parts stash the other night and I figured I would use those for my Reed Conversion since I'm trading my Late model 72 T500 off in the next few weeks.
Hang me from the Tree of Shame.Damn! I forgot the Rope.
- Supreme UFOB
Hi juggie, hope you are well mate
The later jugs are identical except for the bridge in the intake port which you can easily cut down or in your case take out.
The intake length was modified by a bolt on manifold.
If God had intended us to drink beer, He would have given us stomachs. (Suzuki Compendium - www.ozebook.com)
T500 reed cylinders
Any pictures of the T500 reed cylinders?
Any porting specs?
Kris
Any porting specs?
Kris
- Jughead
Instead of building up the rear of the 500 cylinder with weld as you did before my suggestion would be to mill back the intake side of the cyl like Tom did on his 250 till you get a flat surface big enough to mount the reed blocks to , this also gets the reeds / carbs in closer .
It's not a weld fill, just a bit of filling in. Juggy's conversion will be total "stealth"........Suzukidave wrote:Instead of building up the rear of the 500 cylinder with weld....
Any guesses on which reed block is good for just under 100 crank HP on a 500?..........
what are the major benefits to fabing up a reed induction system? This T500 is actualy the first piston port motor i have owned. everything else im familiar with is the reed induction on sleds, stand up jet skis, dirt bikes and what not. so maybe a better question is what are the hold backs of a piston port motor??
The holdback is the reversion in the intake track. Without a reed valve, part of the intake charge is pushed back through the carb, reducing power and causing double carburation, as fuel is picked going in both directions in the carb. So you get a extra rich mixture and inefficient crankcase compression. This gets worse as you add intake duration for more power.tygrant351 wrote:what are the major benefits to fabing up a reed induction system? This T500 is actualy the first piston port motor i have owned. everything else im familiar with is the reed induction on sleds, stand up jet skis, dirt bikes and what not. so maybe a better question is what are the hold backs of a piston port motor??
The reed valves stop the reversion, traps all the intake charge in the crankcase, allows for maximum intake duration and allows for extra ports off the intake for more transfer area........
Ja-moo, makes total sense, i actualy thought that might happen when i first looked at a piston port motor, I remember thinkin hmmmm. thanks for the answer, how much can one gain from adding reeds to a motor like the t500, what else has to be done
edit also when its done do you cut the piston skirts down? would make sense if the port opened sooner right?
Tygrant,
The way to think about reeds is that they allow you to raise the state of tune without all of the harmful side effects.
Just fitting reeds won't make much difference to most motors in terms of power. On some it will improve the bottom end. If the reeds are small they will tend to restrict flow and top end performance, and too large and they barely open, so that's not a lot of use either.
So if you intend to tune a motor especially if you want more intake duration from shorter piston or from dropping the floor of the intake port, reeds help to avoid a big loss of tractability.
Reeds do not open instantly, but take a finite time to open and close. Stiff reeds are even harder to open and are better for race motors because they don't flutter as much as less stiff reeds.
Sometimes, smallish reeds that open very wide can flow better than big reeds that don't open as easily. Reed block angle also effects the way a reed flows.
On a TZ race bike reeds cost power but make teh bike easier to ride. A TZ700 makes about 90HP with reeds and with a pair of TZ350 cylinders with identical porting it makes about 115, but it's almost unrideable.
It's not the difference in top end that makes the difference, it's the way it comes on the pipe - the sudden transition from inefficient to efficient at lower revs.
But in a high performance two stroke that's rideable, reeds are a must.
It all comes down to porting and intended use.
