T500L Losing volts
malky
Suzuki 2-Strokes: GT750A T500K T500L GT500A GT185A RV125L COLLE
T500L Losing volts
Post by malky »
Hi all,
my T500L is only getting 7volts at the tail/brake lamp connections - to me this seems like a big drop,I have cleaned all the terminals and earth connections but that hasn't made any difference - is this normal or am I looking for a fault that is not there - I am using the twin bulb set up from an earlier bike fitted with LED bulbs but without the engine running there doesn't seem to be enough power to light the stop lamps .
cheers
Mal.
Re: T500L Losing volts
Something is wrong. The voltage drop from the battery + to the bulb + should be something like 1-1/2 V.
Make sure your battery is fully charged. No point in ruining a battery while you figure this out.
Use a multimeter & a wiring diagram. Check the voltage at various points between the battery + & bulb + to see if you can find the big voltage drop.
If your bike has a kill switch, set it to off. This way you won’t overheat the coils & the battery charge will last longer.
Wiring diagram is here:
viewtopic.php?f=29&t=4743
dollydog
Country: england
Post by dollydog »
i've had this on different suzukis i've been refurbing and every time it's been an earth connection. have you cleaned and checked ALL the earth connections? :D
malky
Post by malky »
Thanks for the input guys - have checked and cleaned all the earths and I'm pretty confident that they are ok ,I have run a separate earth lead directly from the battery to the frame as a belt and braces step but its still the same
malky
Post by malky »
problem solved - faulty new battery - substituted a 12v power source and getting 11.75v on both live contacts so just ordered a new AGM type battery to go on there :up:
The stock voltage regulator is pretty lame. It’s considered ok for the voltage at high rpm to be 16V.
You should use a modern rectifier/regulator with modern maintenance free or AGM batteries.
johnakay
I likes them jubblies
Suzuki 2-Strokes: bike
Post by johnakay »
notice your in wales.
try rexspeed reg/rec all in one unit. .
I just bought one £60
