Gouge in Front Hub
grumpy56
Suzuki 2-Strokes: 1970 T350 Restored; 1972 GT380 Build
Gouge in Front Hub
Post by grumpy56 »
Have a gouge in the front hub that I want to fill in and then polish to match the rest of the hub. Too deep to grind. Any suggestions as to what to use? Thanks.
rodent
Suzuki 2-Strokes: '73 GT750
Re: Gouge in Front Hub
Post by rodent »
Get it Tig welded?
grumpy56
Post by grumpy56 »
Hey Rodent. Yes that is an option, but its pretty small and have to consider the time (COVID) and expense.
daxman
Country: United Kingdom
Post by daxman »
The disc hubs appear to be quite rough cast and don't polish easy. in any case you don't see much of it with the disc fitted. I'd fill with two part epoxy putty and spray paint it.
Then again you might be talk about a drum hub.. in which case you could experiment with epoxy putty mixed with aluminium filings maybe.
grumpy56
Post by grumpy56 »
Yes it is a drum hub which is pretty visible. I might try to mix some aluminum shavings with JB weld or something similar to try to get something that is close in color.
daxman
Post by daxman »
The putty I use is grey to start with adding some shavings/filings will help I'm sure - its called Quiksteel I think. Its good gear I rate it over JB stuff.
grumpy56
Post by grumpy56 »
Thanks Daxman
