Turn Signal Brackets
- Suzuki 2-Strokes: 1970 T350 Restored; 1972 GT380 Build
Why are the brackets used to mount the rear turn signals on a GT380? I don't have the signals yet, but it would seem that they would just screw into the frame. Anything to do with minimum separation distance? Thanks.
Re: Turn Signal Brackets
A styling issue.
On the T250/T350 twins, Suzuki mounted the turn signals above the grab rail / luggage rack. So rear turn signals attach directly to the frame.
On the GT380/GT550/GT750 triples, Suzuki mounted the turn signals below the grab rail / luggage rack. Doing this required that little bracket.
There is a turn signal separation requirement, which varied over the years. Not sure what it was back then. But that might be another reason for the little brackets.
- Country: WALES
And according to OJB the brackets were only fitted to US and Canada models.
98 carb Blackbird and GT550j
Thank you both. I thought I remembered all I needed to know about these scoots from the last time I had one (1973), but as it turns out, don't remember anything!!!!!
