pressure test
smokie
pressure test
Post by smokie »
I really like this idea because the top end dosent have to be assembled. Just make a template (with a tube for the rods),plug the oil and sris hoses and pressurize. Anyone else try this and do I have it right? I assume the same procedure holds true for the Suzuki triples.[img][img]http://i578.photobucket.com/albums/ss22 ... se_001.jpg[/img][/img]
H2RICK
Country: CANADA
Post by H2RICK »
Yep, that's the way to do it, Smokie, IF/IF you have access to that nice acrylic tube, acrylic plate, a lathe, a shaper and a drill press. Of course the crank assembly with all its seals would have to be installed in order to get any real results....... :wink:
GT550A Mint & Original
MBD Sufferer
