TS125 electrical help needed
jrobinsonusaf
Country: United States
Suzuki 2-Strokes: TS 125, 1970, 1972, 1980
Post by jrobinsonusaf »
I bought a basket case 1972 TS125 and am rebuilding it. I am okay with mechanicals, but the electrics smack of the dark arts. Nine connections on a two position ignition switch? Really!? At this point, I am not sure that the wiring harness is complete. I am looking for a decent wiring diagram with legend, but so far, no luck. Can anyone point me to a decent wiring diagram in color with legends or point me to someone willing to answer a few questions concerning the wiring on this bike?
Thanks, JR
Zunspec4
Re: TS125 electrical help needed
Post by Zunspec4 »
Hello JR,
I restored a TS125 a couple of years back and have a Suzuki workshop manual which has several wiring diagrams. I believe my own model is 1978 TS125C so I colourised the cct diagram. Here's links to the 2 I did (in MSPaint, a labour of love :D).
Cheers Geoff
TS125ER
https://www.flickr.com/photos/zunspec/3 ... 5/sizes/o/
TS125C
https://www.flickr.com/photos/zunspec/3 ... 6/sizes/o/
jrobinsonusaf
Those should put me in business. I can at least get a wiring harness made. The only major difference I see is that I think the US model uses a capacitive discharge ignition, and the CDI box was apparently missing when I bought the bike.
Thanks,
Joel
Zunspec4
Post by Zunspec4 »
jrobinsonusaf wrote:Those should put me in business. I can at least get a wiring harness made. The only major difference I see is that I think the US model uses a capacitive discharge ignition, and the CDI box was apparently missing when I bought the bike.
Thanks,
Joel
Hi Joel
If you can tell me the exact year and model I'll check the workshop manual and see if there is a US specific cct. diagram. It will be in black&white though :D
AFAIK all TS125's in your timeframe used magneto ign/charging. The electrics are pretty crude compared to later standards.
Cheers Geoff
Parts diagram for the 1972 TS125 shows a simple magneto with points: https://www.partzilla.com/catalog/suzuk ... 25/magneto
The wiring on the TS series bikes can be rather confusing, so look closely.
They have a half-wave rectifier. Some electricals (lights, horn, etc) run on AC & some run on DC.
jrobinsonusaf
jabcb wrote:Parts diagram for the 1972 TS125 shows a simple magneto with points: https://www.partzilla.com/catalog/suzuk ... 25/magneto
That has been a confusing issue, since all of the history on this model states the bikes came with PEI (Pointless Ignition System). I will be pulling the side cover of the engine to check, but I am pretty sure my bike does have points based on the wiring diagram Geoff provided.
Thanks,
Joel
jrobinsonusaf
Thanks,
Joel
Hi Joel
Cheers Geoff
Geoff,
I sat down last night with the remnants of the wiring harness and your diagram and did some comparisons. Your colors saved the day. I have to pull off my side cover to verify, but it looks like I do have a magneto/points system, not a PEI system, which will save me a lot of hassle. As soon as I get the front end back from the shop, I'll post some pics. I am actually building a bike to represent a mid 30's European lightweight motorcycle, much like the Royal Enfield Bantam and NSU predecessors. Oddly enough, Harley Davidson produced a post war bike based on the Enfield, and I have been able to pick up a '49 Hummer frame. The engine and wheels mounted with a little tweaking, and I am now ready to build the wiring harness. The information you provided will be invaluable.
Thanks again,
Joel
Zunspec4
Post by Zunspec4 »
Hi Joel,
That sounds like a fun project. Keep us all updated on progress.
Cheers Geoff
jrobinsonusaf
Geoff,
I was able to use your wiring diagram to design a new harness for my project. I deleted a lot of equipment as I will not be using instruments, turn signals or a front brake light switch on this project. I do have one lingering question. What is the purpose of the magneto resistor, and A) do I really need it, and B) what is the impedance on this resistor?
Thanks again, and as soon as I get my front end back from the welders, I can get some pics to post.
Joel
Zunspec4
Post by Zunspec4 »
Hello Joel,
Did I mention that the electrics were rather basic on these :D .
The "magneto resistor" is there to soak up (i.e. dissipate via heat) excess power generated by the lighting coil when the lights are not being used. The lights are a.c. power BTW, Indicators/brake light are powered by the 6v dc. Note on my TS125 the battery needs to be good otherwise the ac can blow the bulbs. The battery seems to act as a regulator keep the ac voltage from rising too high. The ignition is totally independent from the rest of the electrics and the engine will run without them.
Cheers Geoff
jrobinsonusaf
Do you happen to know the impedance on this resistor? I cannot find a factory item, and I figure that so long as I have the proper resistance, I should be able to use a generic resistor.
Thanks again,
Joel
Zunspec4
Post by Zunspec4 »
Hi Joel,
I will have look in the workshop manual for any specs. Failing that I'll measure the one on my bike and get back to you.
Cheers Geoff
Zunspec4
Post by Zunspec4 »
Here you go, Joel.
4 ohms - 22.5 W
Mine mounts to the battery box, near the half wave rectifier and is wire wound. When looking for this in the manual I noticed that cct. diagrams for USA models sometimes showed an actual regulator in the circuit.
Cheers Geoff
