Mikuni TM 34-2 flat slide carb
- Country: United States
- Suzuki 2-Strokes: GT 750B
I have just rebuilt entire engine and had the bike running with Mikuni TM 34-2 carbs. I had problems and was working on the jetting. Has anyone used these before. I have a set of Dave Swarbrick expansion pipes on the bike.
Re: Mikuni TM 34-2 flat slide carb
What jets and needles are in there now and what is the bike doing that's not right?
TM34-2
280 Main
25 Pilot
Q2 jet
5FP127 needle
50 Starter jet
I have the slides raised .030" using the idle stop screw to set this.
The bike will not turn over. Timing is right and there is spark. I lent my compression tester out but it is fresh bore and hone and new pistons and rings.
280 Main
25 Pilot
Q2 jet
5FP127 needle
50 Starter jet
I forgot the pilot air screw is out 1 1/2 turns.
Individual pod air filters.
