I need to strip and clean the caliper on my 380.
Am I right in thinking that, when I've pumped the piston out using brake pressure, if I tie the brake lever back to the twistgrip it will stop all the brake fluid draining out of the master cylinder?
If so, this should make it much easier to bleed the system up again ...
Dumb brake question
Dumb brake question
Theres no big deal, just apply a syringe with a hose to the caliper bleeder and suck the new brake fluid down while pumping on the brake lever during the refill of new fluid.
