Micron wrote:I did swap the plug leads round, as someone on the RD owners club suggested ( I own one of those too), and it fired up, but would not tick over, then it stopped and hasn't really been running since.
I did notice that the left hand back was oiling up a lot, and I noticed that fuel was leaking out of the same carb.
I took the carb off, and removed the bowl, as I had looked at this one before, and I wasn't sure if I had put the floats back correctly, I need to take the other off to make sure? The fuel isn't leaking anymore, but who knows why?
So any ideas as to why one plug oils up and the other doesn't, i'm getting a spark on both plugs?
Thanks for the replies, much appreciated
Trev
aha. So it is a combination of things. Sounds like you have carb problems now you have fixed the ignition problem. If fuel is leaking out of the carb, your float valve is not closing. Either you have dirt in the valve, it is badly adjusted or you have a damaged float.
Solution:-
Strip the carb
Inspect the float needle. Does the end cone have a ridge on it due to wear? If so you need a new one.
Is there a chunk of debris stopping it from closing?
If the needle and seat appear clean and undamaged, inspect the float. Does it have any fluid inside it, indicating a hole? Is it bent?
If nothing appears damaged, dirty, bent or worn, strip the entire carb removing every jet, adjuster and needle and blow it all out on a high-pressure airline making sure you do it thoroughly, blowing air through every hole and aperture (this is to save you finding out later that you have a blockage due to disturbing a small piece of dirt whilst working on it. Trust me, this is not a waste of time).
Then rebuild the carb leaving the float assembly until last.
Now assemble the float assembly and set the float height by carefully bending the tang on the float that presses against the float needle to the
exact level your workshop manual specifies (even 1mm out of spec can cause you serious hassle). On some carbs you have to set the level with the carb upside down on the bench. On others you do it with the carb on its side. Your Haynes manual should tell you which is right for your model.
Before you connect your clean and correctly adjusted carb to the fuel supply again. Make sure you have an inline fuel filter installed. This is an essential item on any classic bike if you want to avoid running problems and recurring headaches.
Balance your carbs by checking that they both open equally at idle and when you open the throttle.
Adjust the pilot air screw by turning it out about 1.5-1.75 turns (you can fiddle with it more later once you have it running, if necessary. Your Haynes manual may tell you how many turns it should be for your particular model, but it is only ever a rough guess for DIY mechanics. The best way to set it is using a gas analyser, but most folks don't have that).
Good luck
Tom
