X7 front sprocket wobbly!?
X7_caferacer
Country: United Kingdom
Suzuki 2-Strokes: GS650Katana GT185 GP100 GT250X7
Post by X7_caferacer »
Hello, just put the front sprocket back to standard and noticed the old and new are a bit wobbly on the shaft. I've used both washers (the toothed and tabbed ones) and yes the locking one rotates in the groove and locks behind spline when screwed to the sprocket.
So thats it? I cant see that it would ever come off and I guess the chain helps keep it fixed, just a bit disconcerting having it wobbly!
The shaft spline is a little worn for the front sprocket but the overall method of locking doesnt seem fantastic? Would I be OTT to put two lock washers on and longer screws!?
thanks!
Steve
Re: X7 front sprocket wobbly!?
The front sprocket on those is meant to wobble a bit on the shaft, it helps reduce chain wear by allowing the sprocket to move slightly as the chain tension changes with suspension movement etc. As you point out, the bolts cannot come loose so there's no danger.
