Take a seat because this may take a while.....
This bike started as a freebie score within 30 minutes of posting an ad on the Atlanta Craigslist for "Wanted - 60/70s Japanese Two Strokes". Upon arriving for pickup I found the front tire off and the bike outside for THE LAST 15 YEARS... Oh well, it's free...RIGHT? Anyway the thing had sunk down into the Georgia clay up to the middle of the side covers. The plywood and shingle overhang that originally protected it from the environment long ago ceasing to function... I wish I would have taken some pics when I got it home. Salvaged engine, frame, hubs and tank. The pipes and rims were completely rotted through in MANY spots.
So, I've been collecting some tidbits during the previous 9 months of being stationed somewhat temporary in Ohio. Previously posted under another thread was my first effort in respoking since my 10-speed days. Thanks to Lane, TZ375, and a new truing stand, I think they are right - AND ROUND (Yes Lane - they really are). The hubs were polished prior to assembly - again using hints found here and on the KTW board. Rims are 18 x 2.15 front and 18 x 2.50 rear - Moose aluminum via Dennis Kirk. I can dig up the part numbers if anyone is interested...
I also had a local sandblaster go over the frame - Cost $39.85 out the door... Way less than I though it would cost... After cutting and grinding off the brackets and handles I didn't think I would need (but am assured I will later) it got some zinchrom primer and some gloss black.
Also mounted 100 and 110 BT45s on front and rear respectively...
I will also post this in the tech portion of the board separately:
If you need replacement forks for a GT250 but don't care about them being original, try a set off a Hond* CMX250 Rebel... They are the same diameter as the GT forks and the axle diameter is exactly the same as the GT as well... No shims, special bearings, or else to adapt the wheel to the fork lowers...NA-DA...
Tom
