ts100 (1976) kick starter not engaging.
jpl27
Country: u.k
Suzuki 2-Strokes: ts125x,ts100
Post by jpl27 »
Hi, does anybody have any links or info to help me out with the kickstarter on this bike not engaging.
I have taken of the cover to inspect the shaft and cannot find anything broken or missing.Thanks in advance.
smokin_blue
Country: usa
Suzuki 2-Strokes: www.street-unique.com
Re: ts100 (1976) kick starter not engaging.
Post by smokin_blue »
take a look at the parts diagram on the kick start shaft. There is a drive pawl that engages in an internal gear to create the ratchet mechanism. Usually they get worn. I had a T500 that would hook and miss depending on where in rotation it was and how carefully you engaged it along with how hard you kicked. Does that sound like your symptoms?
take a look at this parts diagram. Item 4 26231-20000 PAWL, KICK STARTER
http://www.beelineyamaha.com/OEMpartfin ... Inc/TS100_(1976" onclick="window.open(this.href);return false;)/KICK_STARTER/091440004/56091440012
Usually they get rounded off and you can just replace the pawl but you will want to inspect the condition of the mating internal gear.
'07 Suzuki SV650
'90 GSX-R1100 streetfighter
'72 T500 with a Lyster frame
'69 T500-parts/project?
'83 GR650-project
Past bikes
'06 Triumph Sprint ST
'86 GSX-R750
'74 GT250/T350 custom
'79 GS750
'74 TS250
'81 TS100
jpl27
Country: u.k
Post by jpl27 »
Hi, the link does not work it says error.
