Pulled the top end and here is what I have.
Scoring on middle piston. Is liquid suppose to be in the cavities in the crankcase around the pistons?
Heads, right being the cleaner side.
Bore is 54 mm stock and they all look like that with my inexpensive mic.
The top of the left piston has a protrusion on top with the center having an indention and the right having indention though less than the center. Is that the start of holing a piston??
This is the worst cylinder (center) the others look okay from a quick look. The center has some scoring.
Recommendations? Hone and new rings, bore and go oversize?
At what point do you know you have to go oversize and how far can you hone one Before having to go up?
