water pump driven gear thrust washer
mikefealk
Country: usa
Suzuki 2-Strokes: 1974 gt 750 , 1965 80 cc
Post by mikefealk »
in the fiche its very unclear. so there is an e ring on the outside of the bearing, then goes the washer, then gear, then another e ring? i think the washer is supposed to be on the outside of the plastic gear, but the gear will rub on the starter clutch if i do not use the washer on the inside of the gear. anyone?
