Blasting cases question & engine paint recommendations
Whit
Post by Whit »
Hi Everyone,
I plan to blast my GT750 cases this weekend with 80 grit glass beads. Everything is removed from the cases. Is there any areas that I should avoid on the cases? I also plan to paint the cases. Anyone have any recommendations on what Rattle Can color looks the best on the cases. Any painting tips are also welcomed. Thanks //Pat
1973 GT-750
1974 Yamaha 360 DT1
1998 Kawasaki 750 Vulcan
Cliff
Re: Blasting cases question & engine paint recommendations
Post by Cliff »
After you blast the cases, power wash them and using compressed air, blow them dry. Get your air blower into every hole! Then power wash them AGAIN and blow them dry with compressed air AGAIN! The blasting media gets everywhere and it HAS to be cleaned out!!
old racer
Country: Wales
Suzuki 2-Strokes: RG250 GT750L GT750 DRAG seelyt500 tr500MK3
Post by old racer »
I would plug all thread holes.
+1 to what they said ! It took me ages to get the cases clean afterwards - and maybe its just me, but there is always that niggle of doubt that I did get them clean enough :? For paint, I just used a brake calliper paint in a rattle can - it has stood up well so far. 8)
karlwse
Suzuki 2-Strokes: none
Post by karlwse »
I like using the Duplicolor engine paint. It's durable and fairly gas resistant. Also, it's available in many colors.
oldjapanesebikes wrote:For paint, I just used a brake calliper paint in a rattle can -
+1 for the caliper paint :up:
motodreams
Suzuki 2-Strokes: Many
Post by motodreams »
New to the forum but I blast most of my parts for resto. Sand or other media ends up everywhere as indicated and its tough to get it all out. Have had no need to cover up threaded holes though. Only sliding or bearing surfaces.
Pete O'Dell
Country: uk
Suzuki 2-Strokes: T500X2 GT500 GS750 GS500/4 KAWASAKI A1 GT250
Post by Pete O'Dell »
put old screws in all the threaded holes you can it saves a lot of cleaning time afterwards
I havent tried it but i have read the beauty of soda blasting is the clean up as the soda just washes away cleanly :up:
I did my 550 with soda and it worked fine. Just very messy as the dust gets everywhere.
Pete O'Dell
Country: uk
soda wont work properly on really shitty cases, I use oxide which does the work and bead to finish
